Intel Core i5-12600K Desktop Processor 10 (6P+4E) Cores up to 4.9 GHz Unlocked Socket LGA 1700 600 Series Chipset 125W |
MSI PRO Z690-P DDR4 Motherboard ATX |
Cooler Master Hyper 212 Halo Black CPU Cooler - 120mm Fan |
G.Skill Ripjaws V 16GB (1 * 16GB) DDR4 3600 MHz CL18-22-22-42 Desktop Memory RAM - F4-3600C18S-16GVK |
Cooler Master MWE 650 Bronze V2 Power Supply - Non-Modular | 80 Plus Bronze Certified | 120mm HDB Fan | DC-to-DC Circuit Design | 2 EPS Connector | ATX 2.52 Version | 650 Watt |
Western Digital WD Black SN770 NVMe 1TB, Upto 5150MB/s, 5Y Warranty, PCIe Gen 4 NVMe M.2 (2280), Gaming Storage, Internal Solid State Drive (SSD) (WDS100T3X0E) |
ZEBRONICS Agon Mid-Tower Premium Gaming Cabinet - Black, ATX/M-ATX/M-ITX, 1 x 120 mm RGB Inner Glow Rear Fan |
GIGABYTE NVIDIA GeForce RTX 3060 WINDFORCE OC 12GB GDDR6 pci_e_x16 Graphics Card (GV-N3060WF2OC-12GD) |
I will add one more 16gb stick later and make my PC 32 gb ram is it ok
Is 650 watt on enough power for the PC ?
Please suggest cooler and don't worry about the case
please tell about the motherboard is b series motherboard overclockable
I'd try to avoid the Coolermaster 212 unless budget forces you to it. Spend maybe 50 or 60 on something else.
You don't need overclocking.
I'd get 2 sticks of RAM sold in a "kit" for a single price; rather than 1 stick. Get either 16 gb total or 32 gb total if you can afford it. Ripjaws is OK. But get a kit of 2 sticks.
If you need 32, get it now. Don't get 16 now and try to add 16 more later.
WD Black SN 770 is good choice.
I have NO idea about the Zebronics case. You should evaluate it for airflow purposes.
I'd be quite suspicious of that power supply. Look for something in the 550 to 650 watt range with a warranty of more than 5 years if possible. Maybe Corsair, Seasonic, Super Flower, a few others.
is it require me to edit a 4k video for youtube to overclock the processor of 12600k your personal opinionNo. 1 stick of 16 is not OK.
If you want 16, get a kit of two 8s.
If you want 32; get a kit of two 16s.
B series not overclockable but so what on a 12600K.
If you DEMAND to overclock, then get z690.
You are asking for problems if you buy some RAM today and then try to add more to it later. Maybe it works; maybe it doesn't. Gamble if you must.
The case choice is important. That case will NOT accommodate a cooler taller than 155 mm.
Zeb Agon
Zebronics Agon Premium Gaming Chassis with vibrant RGB LED lights, USB & audio ports, AIO cooler support, and LED control switch for optimal performance.zebronics.com
Don't choose the cooler UNTIL you decide for certain on the case. Many good cooler are a bit taller...around 160 mm and will not fit that Zebronics.
and I can change the power supply to
Corsair CV650, CV Series, 80 Plus Bronze Certified, 650 Watt Non-Modular Power Supply - Black
is it ok or it require less else more please tell I have watched various video on youtube in India the all are using the 650 watt powersupply so I added in the list
No. Repeat NO. You don't need to overclock the 12600K.
As I said far above, there is very little advantage to overclocking a 12600K.
Do you INSIST on overclocking? If yes, get a z690.
Full stop.
Power supply:
Best thing you can do is provide a link to the web site where you might buy.
If you can't or won't do that, then list the power supplies you can actually find. There's no point in us recommending a power supply you can't find or refuse to buy.
Corsair CV series would not be on my ideal list, but you may have NO other choice. I don't know.
You need to consider quality rather than just the number of alleged watts provided.
No, I cannot.please you can suggest the good powersupply and which is budget friendly
Why did you decide on Z690 rather than B660? What's the advantage as you see it? I don't know any answer to it that's why I am asking
and for 12600k it provides an integrated igpu and I use it initially for taking the display output and when I have more money add the dedicated GPU 3060 and 12600 does not have an IGPU. Why
is this good or am I doing wrong, if please guide me
12600 did not have andy igpu
