[SOLVED] I am currently building a PC in a Corsair Bulldog case. What would be the best CPU cooler for a budget build that would fit in this case?
It is completely fine to use water cooling, just make sure that you case allows you to put in a radiator. For a build of this level though, I think just a regular mounted fan cooler would work fine.
