Hi everyone, I will start off by posting my specs below:
Motherboard: ASRock H97 Pro4
CPU: Intel I5 4690K @3.5GHz
GPU: NVIDIA GeForce GTX 1070 (MSI)
RAM: 2x 4GB Corsair Vengeance DDR3 1600
HDD: 1TB Seagate ST1000DM003
SSD: 240GB KINGSTON SV300S37A240G
Currently I am playing a lot of Battlefield 1, where the recommended amount of RAM is 16GB, I have noticed while playing that on rare occasions my FPS will crash and outright freeze for a few seconds, when I normally run the game on max settings between 80-100 FPS. I decided to try combat the issue with a RAM upgrade and was looking at the Corsair 16GB DDR3 2400Mhz Vengeance Pro Kit. When I checked compatibility lists and such I could find nothing stating whether this RAM was compatible and became a bit skeptical as to what to do? Is this RAM a good choice for my system? Or perhaps you have other suggestions? Thanks a lot in advance for your help.
(I will not be replying for a while as it is 1am right now in the UK... will check the forum tomorrow around lunch time, hopefully earlier. Thanks again).
