I am going to build af triple monitor setup, and i need help.
MikkelTheWolf
Commendable
May 12, 2016
My system at the moment is the folowing:
Processor Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
Video Card NVIDIA GeForce GTX 760
8 GB Ram
RM Series™ RM850 — 850 Watt 80 PLUS
NZXT Phantom 410 Case
Asus VG248QE x 2
I want to make a triple monitor setup, that can run a lot of games on medium or above.
I plan on buying a Gigabyte Geforce GTX 980 ti Xtreme, and the third monitor of the same kind. Is that good enugh? Can a 980 ti run af triple monitor setup very well, or are there better options?
A single 980ti will be able to run three, but you will not be able to fully use that 144 refresh rate, as you already can't with your current setup without sacrificing screen quality. If you want to use a triple monitor setup just adjust to 60 hz monitors and a single 980ti, or get another 980ti to enable higher refresh rates.
You might want to consider dual R9 390x, since they are cheaper, have more video memory and perform really well on higher resolutions.
