I am having a bit of a problem
Tabby_cat290
4
I am using Ubuntu Linux. I was trying to install a Limewire package but as soon as I did it said:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open() failed, please report.
I tried running dpkg like it said, but it needed super user mode, and that's only available as a package!
Can anyone help?
dpkg will often report an error when the --reconfigure worked ok(?), so it's often worth re-trying the install just to see.
if it still complains either use "sudo dpkg --reconfigure -a", if that doesn't work try "sudo su" (to get root access) then "dpkg --reconfigure -a".
