Well last month I got a new case, cpu heatsink, and a ssd to upgrade my pc a bit, but after getting everything setup and running my then at the time gpu decides to start acting up and randomly drop my signal to monitor. I thought it may be a connection or maybe a bad pci slot on the mobo or anything other than my gpu, but I tried an old one and it worked...
So I go ahead and in the mean time decide to just upgrade to a 780 ti cause I was impatient and tax return time. well it gets here and works fine for a good 4 weeks, but last night it dropped the signal to my pc a couple times, and had weird red lines all over the screen I could get into bios but not boot windows... I put in the old card again and everything works! from what I can tell... I really dont know if this is a gpu thing I mean the first one just goes bad outta nowhere and now a brand new 780 ti just does too? I am just at a loss as to what is happening and I do not have another pc to try these cards in. If anyone has experienced this or has any ideas on what I can do to figure out why this is happening? if you need any info just ask and here are my specs...
win7 home 64bit, OS
amd fx 7850 (never oc'd), cpu
asus sabertooth 990fx r2.0, mobo
16gb kingston hyper x, ram
1000w coolmax psu
240g hyper x ssd
1tb WD hhd
nzxt kraken x60
1st gpu was a ASUS HD 7850 2gb
the replacement I used and am currently using since my 780 ti is now not working is a Hd3870
Any help or advice with my issue would greatly be appreciated
win7 home 64bit, OS
1000w coolmax psu
240g hyper x ssd
1tb WD hhd
nzxt kraken x60
