All of a sudden a couple of my fan headers PWM control isn't working. One of the headers I have connected to an EK D5 PWM pump. All of a sudden the pump wasn't running. I went into the bios and double checked it was set properly and it was. Then I switched to voltage and the pump ran at full speed. I switched back to PWM and the fan slowed down to 600 rpms or so and then back to zero. I removed the header from the MB and when I reconnected it would jump up to 600 rpms again and then back to off. I then noticed two of my fans that are PWM will not spin past 600 rpms. If I set them to voltage they turn off. If I leave them at PWM and select full speed instead of normal their speed doesn't change. It stays at ~600 rpms. I have three other identical fans in the system and they will all spin up to ~1450 rpms when I set them to full speed in the bios.
So basically something has gone wrong with the PWM fan control on my motherboard. Does this sound like a bios issue or possibly a hardware issue?
