A Alabalcho Titan Jan 13, 2011 14,016 433 81,090 Mar 19, 2019 #2 It could be that Partition Wizzard (whatever this is) does not support Windows XP, or needs to be installed in order to work properly. Upvote 0 Downvote
D Dave8671 Distinguished Jan 1, 2014 984 39 19,490 Mar 19, 2019 #3 What do you want to do explain please. That error is is stating that dll file is missing. I would suggest this application. https://www.easeus.com/partition-manager/epm-free.html I use the Todo backup tool for images of my disc drives. Upvote 0 Downvote
W windows xp lover Mar 19, 2019 3 0 10 Mar 20, 2019 #4 i tried that too but not working and everything i tried supported windows xp Upvote 0 Downvote
W windows xp lover Mar 19, 2019 3 0 10 Mar 20, 2019 #5 and i do have the kernel32.dll file in system32 Upvote 0 Downvote
ex_bubblehead Titan Moderator Aug 24, 2012 17,701 2,181 89,240 Mar 20, 2019 #6 That error indicates that that particular version of Partition Wizard is not compatible with your specific version of Windows. Upvote 0 Downvote
D Dave8671 Distinguished Jan 1, 2014 984 39 19,490 Mar 21, 2019 #7 What is the service pack version on your system? If you right click my computer than select properties. Yes software has to be installed before you use it. Unless its a portable which just uses a folder to storage the program. Last edited: Mar 22, 2019 Upvote 0 Downvote
D Dave8671 Distinguished Jan 1, 2014 984 39 19,490 Mar 26, 2019 #8 Think upgrading to a newer OS would be of benefit. I do not know the hardware you have or what you are using the PC for. Upvote 0 Downvote
