i wanted to ask if i got this thing
View: https://imgur.com/rpgAAuB
i got no info about this one all i know that its name is
Keendex Kx2381 Networx Type-C
upadate :
Technical Specification:
1 * USB 3.1 Type C Female (Support power charging, doesn’t support data transfer)
1 * USB 3.1 Type C Male (Support power charging & data transfer)
1) USB Type C port can provide fast power charging to Mac Book through 14.5V/1.5A output,
allows you using multiple different USB 3.0 type a devices without worrying about low battery
like this one
View: https://imgur.com/JECmdwd
and from the female side i got a small usb 3 cable to connect to my usb 3 port on my laptop that would effect the bandwidth going through the cable to my oculus quest 2
and even if there is some loss i think its not gonna be worst than my non gaming 5ghz router that is connected to 4 device and most of them active at the same time
the main usage will be to link my oculus quest 2 and charge it at the same time cuz the link cables that have a charger slots is super expensive
thanks in advance
upadate :
- USB 3.1 Type C Male to USB 3.0 Type A Female Adapter / HUB with USB-C Charger Port
- Dimension: 63.52212 mm
- Material: Aluminum Alloy
- Color: Silver/Golden
- Support Device: New Mac book (USB Type C)
- USB 3.0 type a port provides up to 5Gbps super speed transfer
- Plug and Play, no drivers required
- Reversible usb-c HUB can be inserted from both sides
like this one
thanks in advance
