Question I AM SICK OF THIS NOISE AND THIS POWER DRAINING
Feb 12, 2019
I have an acer nitro 5 and there is a low pitch noise coming from the left almost bottom side, it's not the fans, I don't have hhd, it's not the speakers, it's not a coil whine.
My battery is draining fast although it's in perfect condition, wear level 3%
I have a bad charging connecter I have to move it a bit until it's connected I've had it all along tho, never made an issue.
The sound started almost the same time my battery started to drain faster.
I'm trying to hard reset because I'm out of solutions and I'm sick of it.
If you had any suggestion, be my guest.
Sounds like you narrowed it down to an hardware issue. It’s doubtful anything software wise will fix a hardware problem. The offending part will have to be fixed or replaced.
Yea but I'll take every software solution first, I am 99% sure it's some kind of an electric short or something, but I can put my hands on it
