Question I am stuck at bios screen and nothing I press does anything HELP
Sep 2, 2022
16
I upgraded ram, gpu, cpu and psu but everything seems to be working fine but I’m stuck at bios screen and very worried, what seems to be the problem and any suggestions?
Sep 2, 2022
16
Acer B75H2-AD
its a proprietary motherboard so I don’t think you can find much info about it but i tested the cpu and it works fine and managed to use it. Then afterwards I bought a gpu and upgraded it and now here I am. Stuck at bios screen :( without the delete and f12 buttons working/ doing anything
NerdyComputerGuy
1,446
9
19,965
300
Do you still have your old GPU?
Input the old GPU back into the PC and see if it works, did you remove all of the graphics drivers for your old GPU before inputting the new GPU into the system?
You need to use a program called DDU to 'clean and shutdown' the system to remove the drivers before installing a new GPU.
If you still have the same drive with the same windows installation that was running with the old hardware then this is the reason why it's bugging out.
