HI, I have the following setup:
C2D 6600 (stock speed so far), Tuniq Tower 120, EVGA 680i A1, EVGA GTX Overclocked Edition, and the mighty Corsair Dominator 9136 (that cost me $440+ alone), X-Fi FPS Extreme, 1*320G WD 16MB cache , Powertek 750 Watts PSU, Xcilo Windtunnel Case with lots of airflow (2*250 mm side vents, 2*120 Sunon intake and outake vents) and on top of that Corsair Airflow memory fan is installed. 8) (a good setup i assume)
the thing is that BIOS and CPUz read the memory as 800 MHz only, and I have noticed that the CPU runs at 2400 (stock 9x multiplier) and suddenly it switches to 1600 (6x multiplier) :x , I am not using any special settings at all, every thing in BIOS and windows is running on the defaults, also I have not flashed the BIOS yet to the P26 (I'm not sure if i have too).
the system is very stable runniong orthos with some amazing cool temps... I guess this is the only benfit of running at so low speed for the memory and CPU :?
what can I do to get the correct memeory reading (THG recommended these and this is basicly why I bought them 8O ), and what about the sudden drop of the cpu speed.
Thanks gues for your help.
