[SOLVED] I am trying to order a pc but need advice.
Mar 13, 2019
6
I am ordering a PC build , I have limited knowledge on video cards and memory and non existant on motherboards of what is good and bad when it comes to hardware components and I am not even sure this is all compatible together. and I am not really sure if the power supply is sufficent for this build?
If you could tell me what you think of these items and what I am missing please let me know.
  • CARE1: Cooler Master Mastergel Maker CPU-Thermal Compound Optimized for Thermal Dissipation
  • CAS: CYBERPOWERPC X-Saber 620 ARGB Mid-Tower Gaming Case w/ USB 3.0, Full-Size Tempered Glass Window (Black Color)
  • COOLANT: None
  • CPU: AMD Ryzen 7 2700X 3.7GHz [4.3GHz Turbo] Eight-Core 20MB Cache 105W Processor
  • CS_FAN: Default case fans
  • FAN: DEEPCOOL CAPTAIN 240EX 240mm Radiator CPU Liquid Cooler w/ Copper Cold Plate (2x CyberpowerPC 120mm Dual Light Loop ARGB 1200RPM Fans w/ Hub + Remote [)
  • SSD: 3TB (3TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD
  • HDD: 500GB WD Blue Series SATA-III 6 Gb/s SSD - Seq R/W: Up to 545/525 MB/s, Rnd R/W up to 100/80k [-2] (Single Drive)
  • HDD2: None
  • IUSB: Built-in USB 2.0 Ports
  • KEYBOARD: CyberPowerPC RGB 7 Color Premium Gaming Keyboard
  • MEMORY: 16GB (8GBx2) RGB Lighting DDR4/2400MHz Dual Channel Memory (GSKILL Trident Z RGB)
  • MOTHERBOARD: ASUS TUF X470-Plus Gaming AM4 ATX w/ RGB, USB 3.1, Realtek LAN, 2 PCIe x16, 3 PCIe x1, 6 SATA3, 2 M.2 SATA/PCIe
  • MOUSE: CyberpowerPC Standard 4000 DPI with Weight System Optical Gaming Mouse
  • NETWORK: Intel EXPI9301CTBLK Network Adapter 10/ 100/ 1000Mbps PCI-Express
  • OS: Windows 10 Home (64-bit Edition)
  • POWERSUPPLY: 600 Watts - Thermaltake SMART series 600Watts 80 Plus Gold high-efficient Power Supply
Looking at the available choices on Cyberpower's site, I would say get the 650 watt Corsair TX-M series psu. The Corsair TX-M series psu's have good recommendations from Jonny Guru, Tom's Hardware and Anandtech.
sorry about the graphics card, thought I added it. Here is the graphics card. XFX Radeon RX 590 FATBOY 8GB GDDR5 Video Card [VR Ready] (Single Card)
so would upgrading to
16GB (8GBx2) DDR4/3000MHz Dual Channel Memory (GEIL EVO POTENZA)
do the trick?
Don't know the prices at Your place, but i would exchange rx 590 for rtx 2060 or at least 1660 ti (depending on the budget). Both are way faster and only a bit more expensive.
Edit: yep, You could think of something more reliable than Thermaltake PSU. However, it should still work OK.
SO i can afford to upgrade to
GeForce® RTX 2060 6GB GDDR6 (Turing) [VR Ready] (Single Card)
800 Watts - Standard 80 Plus Gold Certified Power Supply better?
