Hi,
As I mentioned, I am hoping to upgrade my GPU soon but I am unsure as to what I am capable off in regards to motherboard size and CPU. I am also currently limited by my power supply which is only 420W. I may upgrade that it depends on my options and budget.
Current GPU is Nvidia GeForce GTX 650
CPU is Intel core i5-3470 @ 3.20 ghz
Mobo is Asus p8z77-v LX
Power supply is 420W
8GB of RAM
I have looked around the forums but I am still unsure of my options.
I am looking at maybe a GeForce GTX 960, if that would work? It mentioned in the specs on the GeForce website it only needs 400W minimum power for that GPU.
Please let me know if that card is suitable, or if I can go better. Also what I am able to get if I get a larger power supply, and what size power supply i'd need.
Thank you in advance guys. I love Tech Gurus you run the whole world, keep up the good work!
- Jinchu
8GB of RAM
- Jinchu
