Question I applied thermal paste around 10min before seating cooler, was that too long, should I reapply?
alphacoyle
332
14
18,795
This was my first time applying an aftermarket cooler (Noctua NH-U9S) and I spent about 10 minutes after applying the paste figuring out how I wanted to reattach the fan before seating cooler. I used the NT-H1 thermal paste that came with it. I can see a little bit over the edge in one spot but nowhere else--I used 5 dots and tried not to use too much. It's been years since I applied thermal paste and was distracted by the cooler, forgot that the paste dries quickly. Did I wait too long & should I reapply or is it ok?
If they were dots and you were able to compress the cooler onto the cpu easily I wouldn’t worry. If it hardened and you somehow ended up with spaces between the dots I suspect your thermals will let you know.
Its fine.
Consider how long the preapplied paste site on a 3rd party cooler before installation.
Week/months.
Reactions: alphacoyle
