Question I cant connect via modem directly with ethernet cable but if i put a switch in it connects right awayy
leekon1991
23
  • Alienware area 51m
  • n/a
  • Xfinity XFi Gateway
  • OS Name Microsoft Windows 10 Home
    Version 10.0.19045 Build 19045
    OS Manufacturer Microsoft Corporation
    System Name DESKTOP-VA78SM6
    Processor Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz, 3600 Mhz, 8 Core(s), 16 Logical Processor(s)
    BIOS Version/Date Alienware 1.27.0, 6/30/2023
    SMBIOS Version 3.2
    BaseBoard Manufacturer Alienware
    BaseBoard Product Alienware Area-51m
    BaseBoard Version A00
    Installed Physical Memory (RAM) 32.0 GB
    Killer E3000 2.5 Gigabit Ethernet Controler
  • Comcast using wifi currently
  • 3 phones. PS5, 2 Tvs, 2 Pc's connected to wifi,
WIRED LAN CONNECTION ONLY
If you are operating on a wired connection as opposed to wireless these items will also need to be provided:
  • switch is Netgear 5 port Gigabit Ethernet Switch G56605v5
  • security cameras are connected via ethernet but no pc currently.
  • no router or switch currently will explain later
  • internal connecter to use cable
  • Ok, my issue is i can't connect to my modem directly with an ethernet cable my network adaptor flops between identifying and no ethernet cable plugged in. if I hook up my switch and use it it will connect straight away. i have reset my network via Windows and reset my modem using 5 different cables. my other desktop wont connect the same way either. but devices like my security cameras will connect via ethernet cable.
More information needed.
Connection path being the following line diagram where ----> represents an Ethernet cable:
ISP === (coax, DSL, fiber) ===> Modem ---->[WAN Port] Router [LAN Port] ----> [LAN Port] Office Wifi Access Point ~~~~> Wireless network devices
With other Router LAN ports -----> Wired network devices.
Feel free to update and edit/ correct my line diagram as necessary to match your network and connection paths.
Be sure identify modem, router, and switch via make and model.
Show the connection paths with and without the switch?
Do you have full admin rights to the router? If not, who does?
