I can't decide between these two fans
Apr 3, 2018
6
I am currently in the process of deciding what I'm going to get for my pc and I couldn't decide on these two fans. The Corsair - LL120 RGB LED 43.2 CFM 120mm Fan has LED's which is what I want however the NZXT doesn't and if I go for the NZXT I'll add the Phanteks Halos RGB Fan Frame and add it on top. I'm afraid that if I go for the second option, the case fan will look really chunky and I want it to look clean.
If you have any ideas or advice, please reply!
Many Thanks!
I would agree with you on that, however, the NZXT fan seems to be a better fan. I'll probably just go with the Corsair in the end and also would any of you happen to know what a bearing type is e.g. the Corsair is a hydraulic bearing type and I don't understand this.
Thanks again!
I found out it is a good fan however it's more expensive than my budget! I may consider it if I plan to upgrade in the future.
Thanks for the reply!
