[SOLVED] I can't find a pc case please help!!!
Dec 30, 2018
Having trouble finding a pc case to fit all my parts...
I am water cooling my PC so I bought two 360 radiators (they fit three 120 fans so they are quite long). I also want a dvd drive.
The problem is I cannot find a pc case that fits both radiators and has space for a DVD drive. I had bought a core x71 case from thermaltake a week ago but the mobo that I was using (rog maximus xi formula) had an integrated io sheild so none of the cases's screw holes would be aligned to the motherboard.
If anyone can find a full tower pc case that fits two 360 radiators and has space for a DVD drive that would be amazing.
How much are you willing to pay for the case? You realize that most case's these days don't have optical drive bays anymore. There are a handful that still do but most of them don't. You may need to simply buy an external USB optical DVD or Blu ray drive if you want to be able to mount dual 360mm radiators.
Latest posts
