P petarmadar24 Oct 27, 2018 16 0 10 Oct 28, 2018 #1 I can't find where the serial number for my power supply is. Its Zalman ZM-600 GMV. I checked on the actual unit on the box and searched on google where to find it but found nothing if someone has any idea or actualy knows that would be great.
Solution jimmysmitty Oct 28, 2018 Should be a sticker like the one in this picture: https://www.tweaktown.com/image.php?image=imagescdn.tweaktown.com/content/5/1/5144_11_needs_images_zalman_zm1250_platinum_1250w_80_plus_platinum_power_supply_review_full.jpg Did you buy this new or was it part of a prebuilt system?
COLGeek Cybernaut Moderator Apr 6, 2009 59,528 5,294 184,340 Oct 28, 2018 #2 Post a picture of the label of your PSU. Also, it may be hidden from view on the PSU itself when mounted. You may have to remove the unit to locate. Upvote 0 Downvote
P petarmadar24 Oct 27, 2018 16 0 10 Oct 28, 2018 #3 https://imgur.com/a/BrpOJwn I could only find these on box and on top of the unit itself don't think its any of them Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 595 59,140 Oct 28, 2018 Solution #4 Should be a sticker like the one in this picture: https://www.tweaktown.com/image.php?image=imagescdn.tweaktown.com/content/5/1/5144_11_needs_images_zalman_zm1250_platinum_1250w_80_plus_platinum_power_supply_review_full.jpg Did you buy this new or was it part of a prebuilt system? Upvote 0 Downvote Solution
P petarmadar24 Oct 27, 2018 16 0 10 Oct 28, 2018 #5 I just ckecked the receipt and it is the serial number that is on top of power supply and side of the box it just didn't say S/N Upvote 0 Downvote
