Question I cant play many games (Unreal engine is exiting due to D3D) (Display Driver nvlddmkm Stopped Responding)
Hongo
Commendable
May 14, 2020
4
Some days ago i started having some issues that dont let me play some games i use to play like Smalland, Dead by daylight(and rarely on Fortnite) (but never on Valorant, and some others game i used to play), i started getting this errors
This is from Dead by Daylight: https://cdn.discordapp.com/attachments/733858773554430042/1096663726440067122/image.png
This is from Smalland: https://cdn.discordapp.com/attachments/733858773554430042/1097022022191689728/image.png
IMPORTANT: Until some days ago i was able to play this game without any issue.
Things i did trying to fix it:
Update GPU drivers
Update Windows drivers
Downgrade GPU drivers to a older one
Uninstall some windows updates
Enable debug mode on nvidia
Add some "TdrDelay" or something like that to regedit
Format Windows with a clean installation
Update my current Windows (10) to a Windows 11
Decrease clock speed with MSI Afterburner
If i miss something i will add it later but i think thats all i did.In case someone needs it here are my PC specs
MOBO: B450M AORUS ELITE
CPU: Ryzen 5 3600XT
GPU: EVGA Nvidia Geforce RTX 2060 KO Ultra Gaming 6GB GDDR6
RAM 16gb DDR4 2400MHZ
1x SSD 500gb
2x SSD 120gb
If someone can try to help me i will appreciate it, i dont know what else can i do
Hongo
Commendable
May 14, 2020
4
Probably it's time to get a new graphics card.
BTW what model PSU are you using? PSU failure can also can be an issue.
The graphics card has only 6 months, i will try RMA but i've heard that they tell that gpu is fine and only lost money of shippings, i have a gygabyte P650B 650W PSU
D
Deleted member 14196
Guest
You have already determined that your video card has failed because it doesn’t work in another PC. Don’t bother updating the BIOS. It would be a complete waste of time and it’s not necessary.
As stated above, it’s time for a new video card
Also, make sure you have a good power supply a quality one when you get your new video card
Reactions: Hongo
