I cleaned a dusty case fan with water
ItsAlex_
Commendable
Sep 27, 2016
32
I have a case fan that is extremely dusty, for some reason i thought that turning on the sink and cleaning the fan would clean it, yes it was cleaned but will it still work? It is still drying as of now
Wouldn't bet on it!
I'd let it dry as long as you can stand it. If you have access to a hair dryer set it on low temp hi flow and work that over fan until it is too hot to handle. Let dry until cool - connect it and hope.
Best I can come up with!
to dry it, take it into an oven and set it to about 70°C if possible (no microwave) 1 hour should be fine.
If using an air compressor, disconnect the pins from the mainboard or keep the fan from spinning while blowing air. Otherwise it could destroy the fan controller/other parts of the mainboard
