i cleaned my motherboard with soap and gasoline and now my pc won't power on
whiteknights
777
hello guys.. so yesterday i found my PC a little dusty, so i decided to grab a big brush, soap and gasoline and cleaned it very well.. i also cleaned my CPU and GPU with water and soap pretty good, i didn't apply gasoline on the CPU though because i felt it might be wrong..
weird thing happened when i tried to power on my pc it won't power up at all.. have i done something wrong?
Reactions: Suparno15
its not a troll, i know that its wrong to clean PC before removing static charge, I'm not an idiot. plus, i didn't apply the gasoline on the CPU
i just used soap with a soft brush, and i used the gasoline on the mobo.
Well you say that. But then you say this
Which kinda negates the first part being soap is conductive and gasoline is a strong solvent and neither should be used to clean a computer component.
Not sure where you got the idea that soap and gasoline are good for cleaning computer parts but they are either a complete ignoramus or they were trolling you. Either way you have destroyed atleast your motherboard. Next time use canned air, a soft brush(soft bristled paint brushes work well) and a dry cloth and if the rush or cloth needs some moisture(caked on dust) use isopropyl alcohol(the stronger the better).
And it isn't even April 1st today :/
Next time I'm not sure how to perform a task on a PC I'll remember to ask my Granny 'cos most pensioners know all about that stuff :lol:
You couldn't make it up :pfff:
