I decided to just build my own computer. I've never done so before. But, how hard can it be anyway?
The reason I'm building a new one is because my Win XP Pro SP3 32-bit one is just too outdated. It can't run Steam. It's browsers are too outdated to surf most of the net.
I will still be using my old XP computer for various games/programs/etc. that will not work on a modern computer. No. I will not change my mind on that any.
I will be connecting the two with this. https://www.startech.com/en-us/server-management/sv411kusb . I simply don't have enough room for more than one keyboard, mouse, monitor, pair of speakers, etc..
I have discovered that this will allow me to use a more modern card. https://www.startech.com/en-us/audio-video-products/hd2vgae2 . It says that it's an active adapter.
Here are the answers to the questions in https://forums.tomshardware.com/threads/how-to-ask-for-new-build-or-upgrade-advice.528714/ .
Approximate Purchase Date: I don't know. Whenever I get the money. I have no idea when that will be.
Budget Range: Hopefully, two, or three, thousand.
System Usage from Most to Least Important: Play Steam games. Surf internet with updated browsers. Use 64-bit programs that XP cannot run.
Are you buying a monitor: No. I've already got one. A HP LE1901w. Here. https://www.bhphotovideo.com/c/product/634741-REG/HP_Hewlett_Packard_NK570A8_ABA_LE1901w_19_Widescreen_Computer.html/specs .
Keyboard: Already have one. Here. https://www.fanficparadise.com/arielschnee/gallery/s-l1600.jpg
Mouse: Already have one. Here. https://www.fanficparadise.com/arielschnee/gallery/s-l1600.jpg
Parts to Upgrade: Everything. Building from scratch. I have nothing right now except for the monitor, keyboard, mouse, and pair of speakers.
Do you need to buy OS: Yes. I'm building it from scratch afterall. I plan to get Win 10 Pro off ebay. Or Win 11. Whichever is better.
Preferred Website(s) for Parts: Dunno.
Parts Preferences: I don't particularly care for RGB. The only time I would want it is if the component is better than the non RGB version. Otherwise, I could do without the RGB.
Case (Phanteks Eclipse P400A High Air-Flow ATX Mid-Tower Gaming Case w/ USB 3.0, ARGB, Full-Size Tempered Glass) (Feel free to suggest something better. It must have USB 3.0 ports, and high air flow.)
CPU (Intel i?-???K) (Something that can be cooled with only air cooling. I DO NOT want the hassle of dealing with liquid cooling.) (Suggestions?)
GPU (GeForce RTX ????) (I NEED one with that can work with this { https://www.startech.com/en-us/audio-video-products/hd2vgae2 }, so I can connect it to this {https://www.startech.com/en-us/server-management/sv411kusb }.)
Powersupply (850 Watts - Corsair RMx Series RM850x 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply) (Anyone know of one that is better?)
Motherboard (Z?90. Must have USB 3.0 ports.)
Memory (32 GB. Two sixteen GBs. Do they make single thirty-two GB sticks? Whatever the best is for this build. I don't know what that would be.)
Case Fans (6X 120mm Phanteks SK120 PWM FAN - high airflow nine-blade 500-1500 RPM Radiator Fans Black) (I saw an add for these somewhere. They sound good. Any better suggestions?)
CPU Cooler (Must be an air cooler.)
Primary, And Secondary, Hard Drives (Must be 2 TB SSD.)
Network (Dunno. I heard about an "Onboard Gigabit LAN Network". Would that work?)
Sound (High Definition On-Board 7.1 Audio) (If you know something better, feel free to suggest it now.)
Speakers (Already have some.)
External Hard Drive(s) (I was thinking of getting a few of these { https://www.bestbuy.com/site/toshiba-canvio-2tb-external-usb-3-0-portable-hard-drive-silver/6377857.p?skuId=6377857 }, and using them with this { https://www.startech.com/en-us/cards-adapters/st4300minu3b }.)
Optical Drive (An External USB DVDRW) (I don't think they make the internal ones anymore.)
Overclocking: No.
SLI or Crossfire: I don't even know what that means.:(
Your Monitor Resolution: https://www.bhphotovideo.com/c/product/634741-REG/HP_Hewlett_Packard_NK570A8_ABA_LE1901w_19_Widescreen_Computer.html/specs .
And Most Importantly, Why Are You Upgrading: Because my Win XP Pro SP3 32-bit one is just too outdated. It can't run Steam. It's browsers are too outdated to surf most of the net.
Ask me if you need anything else.
Overclocking: No.
