Question i dont know anything about overclocking but i need help with overclocking
Apr 16, 2019
Psu: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply
Cpu: AMD - FX-8350 4 GHz 8-Core Processor
Cpu Cooler: AMD - Wraith Max 55.78 CFM CPU Cooler
Gpu: Gigabyte - GeForce GTX 980 4 GB WINDFORCE Video Card
Mobo: Gigabyte - GA-970A-DS3P ATX AM3+ Motherboard
Case: Rosewill - REDBONE U3 ATX Mid Tower Case
Ram: Kingston - HyperX Fury Blue 16 GB (2 x 8 GB) DDR3-1600 Memory
so is there any way i can overclock my cpu or do i need a bigger psu?
overclock settings for Gpu
Power Limit(%): 125
Temp. Limit(C
°): 91
Core Clock: +270
Memory Clock: +450
and when i try heaven benchmark the beginning keeps black screening and goes back and half way through i get blue screen then i have to restart my whole pc, if you can help it would be appreciated thanks
You NEED a higher wattage PSU for that setup, especially when overclocking. That PSU is fine for efficient hardware, not power hungry once high-end components.
For the meantime, turn down core and mem clocks on GPU. It may be unstable due to that.
Similar threads
