I formatted my PC and now I am having problems installing ..
G
Guest
Guest
Archived from groups: alt.comp.hardware.homebuilt (More info?)
I formatted my PC and now I am having problems installing winxp. In DOS mode I
type in setup, and the screen reply, will not run in DOS mode. What do I do?
G
Guest
Guest
Next time just format the hard drive as the 'PeeCee' doesn't need formatting.
> In DOS mode I
Boot from the CD. (change boot order in BIOS if it doesn't). Preferred method.
Or cd to the i386 directory and run winnt. It'll probably be bloody slow
that way because I'm guessing you're booting from a DOS disk without
smartdrive. It'll go faster if you copy the i386 directory to the hard
drive first and then invoke winnt from there, plus you have the files on
the hard drive for any time you add/remove windows features and so don't
need to shove the CD in the drive.
G
Guest
Guest
boot from the CD
"Taylor1n2" <taylor1n2@aol.com> wrote in message
news:20040628224046.16712.00000498@mb-m22.aol.com...
mode I
do?
jeff
1,172
I don't claim to be an expert on the subject but.... as I undestand it
WindowsXP does not recognize DOS during setup. You need to go into
the BIOS and change the first boot drive to CD Rom since the WindowsXP
disk is bootable.
You should be on your way at that point. Post back if that doesn't
work.
Good luck.
taylor1n2@aol.com (Taylor1n2) wrote in message news:<20040628224046.16712.00000498@mb-m22.aol.com>...
G
Guest
Guest
in the I386 directory is "winnt.exe". Run it.
If your boot method didn't load smartdrive, the installer will
probably warn about that, but would run, slower.
http://www.broomeman.com/support/smartdrv.html
Unknown
341
>,;I formatted my PC and now I am having problems installing winxp. In DOS mode I
>,;type in setup, and the screen reply, will not run in DOS mode. What do I do?
Two choices.
1. Go into BIOS and set boot sequence to boot from CD.
2. Download a SIX floppy set that you can boot and then load XP from
DOS.
Yes it consists of SIX floppies. I had to do this recently and it
works. You will need access to the Internet of course to get that set
of floppies.
G
Guest
Guest
Yes, indeed, looks like you're not an expert in tr@olling;-)
Roy
G
Guest
Guest
Why are you at a DOS prompt to install XP???
Boot your computer from the XP CD and follow the directions. It's simple.
DaveW
mode I
do?
G
Guest
Guest
In article <20040628224046.16712.00000498@mb-m22.aol.com>, Taylor1n2
says...
cd i386
winnt
You're trying to run the setup from the root directory of the CDROM
which is a Windows executable. Change to the i386 folder and run winnt.
Conor
Dumb as a box of rocks...
