My GPU usage keep dropping when the wattage for the GPU is 100watt++ even if the gpu usage is 50-60%, so when I game on 99% GPUusage i start getting FPS/GPU usage/WATT drops, maybe someone will say check your temprature but my temprature is under 70 for GPU and under 60 for the CPU while high stress which mean that my temps are good.
i will give example for heavy game as red dead redemption2 online, i play on 1440p lets say normal settings and 100fps, here the GPU usage will be 99% and 200watt which will cause tons of stutters, then I have to lower the resolution to 1080p and cap the FPS to 60 just to make the power under 80watt then the GPU usage is just 60% what a waste of 40%.
Another example for light game which is Rocket league on 1440p and uncapped FPS i can easily hit 400FPS++ which will make my GPU usage 96% and power reach around 200watt which cause tons of FPS drops, so i have to cap my FPS and will only get 40% gpu usage and 62watt usage and waste 60% usage.
So i am not able to use my full GPU power and this is a big problem which annoys me too much because sometimes I need to, also my CPU usage is always less than the GPU so i dont have bottleneck
SPECS:
GPU : ASUS RTX 2070SUPER
CPU : i7 9700k
RAM : 16GB
STORAGE1 : Samsung SSD 500GB
STORAGE2 : WD blue HDD 1TB
COOLER : NZXT KRAKEN X63
MOTHERBOARD : ASUS TUF PLUS GAMING
PSU : CORSAIR 650WATT
MONITOR1 : VG27AQ
MONITOR2 : BENQ ZOWIE 24 inch 60hz
Hope i didnt forget to mention more details and I can provide more details if needed
SPECS:
CPU : i7 9700k
RAM : 16GB
MONITOR1 : VG27AQ
