I got a usb port for my new laptop ASus X507U but it does not work. Is there’s anyone could help me pls.
It does not work my new usb port and cable on my Asus X5070. Don’t know what’s the matter. Anyway I’m using rj45 cable
Your post is a bit confusing, do you mean someone soldered in a new USB port on the laptop to fix it? And what does the rj45 cable have to do with the USB port? RJ45 is used for a network jack.
What exactly is this "USB Port" you got? Are you talking about a USB hub?
Yes, you’re right. i was confused. The usb hub i should say. Technician has checking it but still no solution. The main thing is when i’m using wireless connection is very fast but when i connect into wired lan become so slow, and I dont think the problem is that I’m using 5meters of rj45 cable, and for more info I am using windows 10. help me sort it out this. Thanks
What does the USB hub have to do with the network connection? Or are you using a USB network adapter? A USB hub is just a device used to add more USB ports to a computer. Need exact details of what the issue is, is it a network issue or a USB issue? What are you connecting to with ethernet? Is the slowness on any network? Did you try another cable, another switch/router/modem? What is the connection speed showing up as in properties? What did this technician that check on it try already?
