I have $1300, help me out!
trevortmiller
21
What's up ladies and gents, I'm back. After fixing my beloved computer, I have decided to put some money into it for a better gaming experience. Let's list what I currently have.
Motherboard- Foxconn 2A92
GPU- GTX 760
CPU- AMD Phenom II x6 1090t
PSU- Not sure
RAM- 12GB
Storage- 3 Hard Drives and my OS SSD
What I'm looking for. I want a GTX 980, so I already have that figured out, I just need help finding the rest so it won't be bottle necked. I need a new CPU, PSU, and MB. I'll also need a new cooler for the CPU as well. Thanks for the help. Remember I have $1300 for everything including the 980.
So here's what I've picked out now.
Motherboard- ASUS Z97 (http://tinyurl.com/mn2q3rj)
CPU- i7-4790K (http://tinyurl.com/mtwu2qd)
GPU- ZOTAC GeForce GTX 980 (http://tinyurl.com/nlevf8a)
PSU- XFX XTR Series P1-650B-BEFX 650W (http://tinyurl.com/pvudvuq)
CPU cooler- Corsair H100i (http://tinyurl.com/anzpfmq)
Will the 650w psu be enough for all of that plus three HHDs and an SSD? Also, according to pc part picker my samsung RAM isn't compatible with that motherboard, is that true?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($329.99 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($137.99 @ NCIX US)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($81.99 @ Newegg)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card ($585.91 @ Newegg)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: XFX XTR 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.99 @ Amazon)
Total: $1290.85
Generated by PCPartPicker 2014-10-21 15:06 EDT-0400
honestly, tom's "best cpus/gpus for the money" can answer all these questions for you, if you haven't read those articles already for this month.
what resolution monitor are you attempting to game at? that's the real question. if you're on 1080p, spending $1300 would be kind of a waste of money considering how swell the gtx 760 still is. 1440p may be another story. selling the 760 and getting a (now pretty cheap) r9 290/290x or just adding another 760 would be a pretty good move for 1440p. keep an eye out for gtx 780/780tis on the cheap, since they are being phased out, as well. theyre in and around about as fast as the 980, they just use a bit more juice from the wall.
then get yourself a core i5/i7 and a moderately priced motherboard and you're in business. and you just saved yourself a huge chunk of change.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($229.98 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($94.98 @ OutletPC)
Video Card: Zotac GeForce GTX 980 4GB AMP! Extreme Edition Video Card ($609.99 @ Amazon)
Power Supply: Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply ($264.99 @ NCIX US)
Total: $1337.93
Generated by PCPartPicker 2014-10-21 15:13 EDT-0400
$leet - a bit over your budget, but here.
At the moment I use a 1920/1080p monitor as my main. I have a 1600/900 as well but I usually only leave things like skype open in it. My biggest problem with my current build is fps on Arma 3. While playing the wasteland mod for it, I get about 20 fps.
a new cpu will definitely help with the low fps in arma III. how much, i do not know. but it will still be a massive upgrade if you snag an i5 4690k or i7 4790k
the build is great . 650W is plenty .If the RAM is DDR3 240 pin , it should work .
Edit : Your motherboard should suport DDR3 240 pin . Likely , the RAM will work
http://www.findlaptopdriver.com/foxconn-2a92-mainboard-specs-742010h517p/
Edit 2: Asus Z97-A supports RAM 1333+MHz , so if the RAM is 1066MHz it likely wont work
