[SOLVED] I have 2x8GB 16GB DIMM DDR3 1333 MHz and add 3200MHz?
Marplot
Commendable
Jan 28, 2022
114
8
1,585
I have four slots in my Asus Sabertooth 990fx R.2 mobo with two 16GB DIMM DDR3 1333 MHz and add 3200MHz additional memory? Or Must I should remove the 1333Mhz?
DDR3 as far as I know goes up to 2400mhz. If you have RAM rated at 3200mhz I expect it’s DDR4 which will not fit.
Mixing RAM is always a gamble, might work, might not. If it does work the best you should hope for is running at the speed of the slowest RAM. All RAM in a system must run at the same speed.
