Question I have 5 fans
So if you think of your case as a heater, draw cool air in with fans front, side/s nearest the bottom, and exhaust fans rear and top above the height of the intake fans.
And keep in mind which way the fans are blowing inside the case, like the GPU and CPU coolers, so you get good air movement inside as well. In general: push everything moving from point A (draw cool air in) to Point B (draw hot hair out), as Fit_that_glitch is saying.
