I'll upgrade my psu asap .
Yes, kindly upgrade your power supply.
PSU is the last component you might want to cheap out on, or skimp. Try to get some other high quality PSU, IF possible.
Power supplies are an imperative part of your system that should not be taken lightly. Throwing in a budget PSU could result in poor power efficiency or even a wrecked system. Don't SKIMP on the PSU,, since this is the MOST important PC component. I can't stress this enough.
Btw, this PSU list is NOT exhaustive, nor 100% accurate though, but it gives us some idea about the brand reputation, in the hierarchy list..
PSU brands to never buy from
- Diablotek
- Apevia
- Coolmax
- Logisys
- Sparkle
- Raidmax
- Zalman
- Diablotek
- Xilence
- Tacens
- iBALL
- Zebronics.
- Logisys.
- Average PSU brands (Not deadly but i would avoid them)
- NZXT
- Enermax
- Cougar
- Bitfenix
Good PSU brands (These psu brands have decent-great psu's but also have a few outliers)
- EVGA
- Corsair
- Antec
- Cooler master
- Be quiet!
- Fractal Design
- SilverStone
- FSP.
Arguably the best brands
Conclusion
Most power supplies you buy should be fine as long as you're not pushing them to the very limits. I obviously didn't include every OEM and re-seller but I listed the main ones. Pretty much all PSU manufacturers sell good and bad power supplies, it just takes a little reviewing and forethought into your system requirements before you make a selection....
