I have a Corsair 750D (case) , should i leave the front and top cover off or on ?
omidelf
342
so i already have a good liquid cooler for my cpu and my vga's have a good temp
my question is should i open the front cover of fans and top cover ? will that make a huge difference ?
also why the hell they made this PC like this ? why not just leave the front cover open ?
is this the way its meant to be used ? just the front cover on ?
Sure it's meant to be left on. The front cover helps reduce the escaping noise. If your temps are good, why worry? I'm not sure it would make a difference in temps anyway- try it on and off and let us know. By the top cover I assume you mean the magnetic dust filter? Well, it's helping to keep the dust out.
also do i need to change the dust filters every year or something ? or just cleaning them every 6 month will be enough ?
Nah you don't need to change them, cleaning them is enough.
