A adrian.cox Prominent Jan 23, 2018 1 0 510 Jan 23, 2018 #1 Is there a signal converted anyone can recommend?
Solution bignastyid Jan 23, 2018 You'll need an active DVI-D to VGA adapter. I prefer the ones that use a usb cable for power as they seem to work the best. https://www.amazon.com/gofanco-Pro-DVI-D-Active-Converter/dp/B00RWFT8NG
bignastyid Titan Moderator Jun 19, 2011 33,656 1,674 159,590 Jan 23, 2018 Solution #2 You'll need an active DVI-D to VGA adapter. I prefer the ones that use a usb cable for power as they seem to work the best. https://www.amazon.com/gofanco-Pro-DVI-D-Active-Converter/dp/B00RWFT8NG Upvote 0 Downvote Solution
