K kartume Reputable May 29, 2015 7 0 4,510 May 29, 2015 #1 Looking to upgrade my graphic to a GE Force 970.But I have 2 6 pin connectors.Will this work??This is actually for my Grandson.
Solution SubZeroFlsh May 29, 2015 Hello! What is your motherboard? 1000W is more then enough to power a 970. MSI 970: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16814127832&cm_re=gtx_970-_-14-127-832-_-Product To run this 970 you will need a 6 pin and an 8 pin power connector. ASUS 970: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16814121899&cm_re=Asus_970-_-14-121-899-_-Product This only requires a single 8 pin power connector. If you only have 2 6 pin connectors you will need to purchase an adapter: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16812198016&cm_re=6pin_to_8pin-_-12-198-016-_-Product Hope this helps and please ask any more questions you have.
SubZeroFlsh Honorable Aug 6, 2014 811 0 11,160 May 29, 2015 Solution #2 Hello! What is your motherboard? 1000W is more then enough to power a 970. MSI 970: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16814127832&cm_re=gtx_970-_-14-127-832-_-Product To run this 970 you will need a 6 pin and an 8 pin power connector. ASUS 970: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16814121899&cm_re=Asus_970-_-14-121-899-_-Product This only requires a single 8 pin power connector. If you only have 2 6 pin connectors you will need to purchase an adapter: http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16812198016&cm_re=6pin_to_8pin-_-12-198-016-_-Product Hope this helps and please ask any more questions you have. Upvote 0 Downvote Solution
