i have a issue with gigabyte h97m-d3h motherboard heatsink overheating and system restarting loop
Aug 6, 2018
i have gaming pc with the below config
gigabyte - ga-h97m-d3h motherboard
8gb ram - crucial and kingston 4gb each
msi graphics card gtx 1050-ti oc 4gb
core i3-4150 intel hasswell cpu
cooler master 500w psu b series
seagate hdd - 1tb barracuda x 2
6 cooler master sickleflow fans
i disamble the whole pc and tried removing each part and testing it if any part is causing issue like ram, hdd, cpu etc...
the system restarts after opening it for a few seconds,
this problem started few days back when i was working on a system and system got just restarted and it never stopped it was keep restarting.
i tried updating the bios using usb.
even now the problem is still there
i check if cpu is overheating but its fine
i checked if motherboard heatsink is overheating its overheating, its reaching the temp i can feel a heat upon touching it.
i took a small fan and put upon the heatsink to make it cooler but nothing working.
Aug 6, 2018
i am using this pc for more than 3 years and both memories were working fine, i tried working with single memory stick but now same problem is happening restarting pc.
both memories are compatible with motherboard i checked on crucial and kingston websites
