I own a 250 GB HDD right now that I'm putting into my build. i will use this for a couple months before i have more money to upgrade
I later plan on adding a 120GB SSD as a boot drive and a 1TB HDD for additional storage
1. Will i be able to transfer the OS to my SSD? or will it be easier to disconnect the 250gb HDD and reinstall the OS on the SSD?
2. once the OS is on the SSD it will ask for the product key for my version of windows (right?) since the OS is already going to be in use on my HDD will i need another product code?
3. will i have to get special adapters for my power supply to power 2 HDDs and a SSD?
4.Buying a product code, then installing the OS from the creation tool on a flash drive isn't much different than using a disc right? and the creation tool is free to use, the only thing you're required to pay for is the product code that you input once the installation is complete?
Thank you so much in advance, and if you could label any answers with the number of the question its referring to it would nice!
