[SOLVED] I have a MacBook Pro 2011 and I need help Factory resetting it!
Gwilson101010
After resetting it, now when it boots up it shows like a folder icon with a question mark. I assumed that means I will need to reinstall the Mac OS back on it. But when I go to install it and it says Select the disk where you want to install OS X. There is no disk options available so how am I suppose to reinstall the OS?
