Question I have a new build, PSU works, RAM works, not sure which CPU cables to use. Without CPU cables computer posts, when I add the cables it wont post
Aug 13, 2019
LED Ezdebug "CPU" light on
  • EVGA 750 B3 - PSU
  • X-570-A Pro - MB
  • AMD Ryzen 7 2700x - CPU
  • Gigabyte Geforce GTX 1050 ti - GPU
  • Intel SSD 6
  • Samsung 970 EVO SSD
  • Gigabyte GC-WB867D-I - Bluetooth/WiFi
  • Vengeance LPX DDR4 2x16 (32GB) 3000Mhz - RAM
clutchc
Herald
That first one you mentioned I'd have to see. It isn't listed in the cable selection for that PSU. Unless you are talking about the PCIe 6+2 pin cables. Don't mix them up. They are wired differently. The pos and neg are reversed. In fact, only the 4+4 pin EPS connector should fit the CPU header.
Aug 13, 2019
see link I posted that says my set up
