When I install my 2nd graphics card sometimes it comes up in the device manager, sometimes not. When it does, it comes up with the yellow ! next to it and says "This device cannot find enough free resources that it can use. (Code 12) If you want to use this device, you will need to disable one of the other devices on this system."
Currently my system is a Ryzen 5600x,, with a Aorus X570 Elite motherboard, installed on it is a 3090 in the main slot, SSD Nvme drive in the top slot and a SATA SSD drive as well. Running Windows 64 bit. 16GB 4000Mhz ram.
This issue comes about when I put the 2nd 3090 into the x4 GPU slot of the MB.
Things I have tried so far.
Making sure it is slotted correctly.
Reinstalling the video card drivers.
Changing PCIe Bifurcation settings on the MB.
Just to make you guys aware too that the 2nd GPU (not that I think it would make a difference) is run by an independant PSU (as my original was an 800W Gold, so this is being run by a stand alone 650w bronze PSU)
Please help! I've ran SLI before (not for ages) and crossfire and never encountered these issues, so unsure how to fix it.
This is NOT an SLI setup, these will be run independently.
