I have a problem.....
Carter2point1
14
I have a problem. I am getting a Cooler Master Nepton 240m some time soon for my build. The fans in using are Corsair SP120 PWM version fans, which have an rpm of 2350 and a 4-pin pwm connector... I have two of them with a 4-pin pwm fan splitter to make one connector. My Asrock Z97 Killer motherboard only has 1 4-pin cpu fan connector, plus a 3-pin cpu fan header and a 3-pin power fan header (and other 3-pin case fan connectors). Also i have a 4-pin case fan header. My questions are: 1. What connector does the pump on this cooler have? 2. If its 3-pin, i can use the 3-pin cpu header and i wont have a problem. If its 4-pin, can i use the 4-pin cpu header for the pump, and the 4-pin case fan header for the fan splitter with the fans on it, and will the motherboard recognize it and use those as fans As it would for cpu fans? 3. If that is a problem, can i use my fan controller for the cpu fans, or will that cause a problem or something? 4. I just thought of something else, could i use a 4-pin pwm fan splitter that takes 3 connectors and turns it into one for the pump and two fans and run it off of the 4-pin cpu header... Or will that create a problem as well?
Thank you for your time.
-Carter
So, Im confused.... Does that mean the pump is 3-pin and i can use the 3-pin cpu fan header, and i can use my 4-pin pwm fan splitter on the 4-pin cpu fan header?
