M mushroom2354 Commendable Oct 8, 2016 77 0 1,630 Feb 20, 2018 #1 It says in the amazon page "Computer Memory Type DDR3 SDRAM" What does it mean? If i have ddr4 memory it will not work? I didn't understand this issue. If someone can answer,i will be very happy. Thanks in advance
Solution Phillip Corcoran Feb 21, 2018 That refers to the minimum requirement for reliable disc burning. You've got DDR4 which is faster so that's fine.
Phillip Corcoran Titan Moderator Sep 7, 2013 26,107 912 120,140 Feb 21, 2018 Solution #2 That refers to the minimum requirement for reliable disc burning. You've got DDR4 which is faster so that's fine. Upvote 0 Downvote Solution
M mushroom2354 Commendable Oct 8, 2016 77 0 1,630 Feb 21, 2018 #3 Phillip Corcoran : That refers to the minimum requirement for reliable disc burning. You've got DDR4 which is faster so that's fine. So ok. Thanks Upvote 0 Downvote
