So this is a gaming rig, that being said I do want to use both as the games i play support two sli, not well but there is still a gain of live 40fps with two 1080tis vs a 2080ti. IF i keep the cpu at stock voltage would it be lower, and do you know of any cheap 850s? like half decent sub 90 dollars?Just because you have two 1080Ti cards, does not mean it's a good idea to use both of them - at least if you plan on gaming, since SLI and Crossfire are dying techologies, with vanishing support.
If you're mining, that's a different story. In that case, your CPU overclocked, assume 100W (though probably less), and the 1080Tis are rated at 250W each when maxed out. That's 600W right there, plus a little more for MB, fans, RAM, etc.
If it's an EVGA White, that's one of the lowest quality models they offer.
I would suggest a Seasonic PRIME or FOCUS model, or a Corsair HX, AX, or RMx model. Minimum 850W for this whole setup.
HOWEVER - if this is going to be a gaming rig, put in only ONE video card. Then you can step down to about a 550W or 650W PSU.
240hz, Gsync idk man i think i can get sli to work alright but would two 1080tis be any faster than one like more than 40 frame difference with one more?Just because you have two 1080Ti cards, does not mean it's a good idea to use both of them - at least if you plan on gaming, since SLI and Crossfire are dying techologies, with vanishing support.
If it's an EVGA White, that's one of the lowest quality models EVGA offers, if I recall correctly. I would suggest a Seasonic PRIME or FOCUS model, or a Corsair HX, AX, or RMx model. Minimum 850W for this whole setup.
1080p gaming? What is your monitor's refresh rate, and does it have GSync, FreeSync, or neither?
If you're gaming at 1080p, even a single 1080Ti card is overkill. Even if you could get SLI to work correctly (and that's a big if) with two 1080Tis, it's a complete waste. Don't bother with it.
