I have a recurring problem with hardware. Can't diagnose the issue
Nilangan
64
THE POST IS LONG. PLEASE READ. I have a custom built pc for 6 years now. Core i7 2700k, 1TB HDD SATA, 4GB DDR3 RAM, (ATI 5500HD) and Win 7 64bit and 32bit. I have upgraded my PC on January end. EVGA GTX1060 3GB and PSU Antec VP 450p
The problem started last week. I was using chrome when the screen froze. nothing worked. So i turned it off directly and opened it again and booted to the same OS i was using prior to the freeze(Win 7 32bit).
It logged in successfully but after logging it showed Nvidia share stopped working, windows explorer stopped working and was super laggy. I thought the files were corrupted on this windows so I turned off the pc and turned it back on a different copy of windows I already had on another drive. Win 7 64bit. It booted too and showed the same errors.
Next time I tried to boot it showed DISK READ ERROR Press Ctrl Alt Delete to restart. I turned it off and turned it on again this time it booted and showed the previous error I mentioned. I tried turning off and turning it on now it kept showing DISK READ ERROR Press Ctrl Alt Delete. I also tried selecting integrated graphics from the BIOS and plugging the DVI cable into the Mobo slot. It still showed the same error on boot. I unplugged everything, unplugged RAM cleaned plugged everything back in and it worked fine for a week.
Yesterday screen froze for few seconds then it went black and came back on showing Nvidia driver/kernal stopped working and has successfully recovered. Nothing happened then.
Today morning when I was trying to boot it was stuck on windows boot screen. I restarted and everything worked fine for 4 hours. I was using chrome when BSOD happened. I restarted and got DISK READ ERROR Press Ctrl Alt Delete I restarted again and it was stuck on Windows boot screen I turned off and restarted it booted fine didnt show any errors. I opened my computer it was fine. I opened chrome it loaded. I opened a sheet on chrome and it showed Aww Snap error. then suddenly I was getting crash errors from all the nvidia files. and suddenly the GUI went to basic mode. and i had to turn off.
So I opened the case and removed and reinsterted the hard drive cables pressed the GPU and Ram and other cables in case they were lose and restarted and it loaded with checkdsk and fixed few corrupted files which after completion loaded fine. The screen froze once while using chrome turned black and turned back on and showed that Nvidia driver stopped working and recovered error. Its working fine since then(been 20 minutes).
PS- I think i need to mention something after upgrading my PSU (was using previous graphics card), it showed DISK READ ERROR Press Ctrl Alt Delete to restart error while booting. I used another cable from the PSU for the harddrive and it has worked for 3 months no issues. So I am not sure if its relevant to the current issue.
REQUEST TO MOD> I can't post thread as discussion, it automatically changes to question. Please delete the duplicates.
MERGED QUESTION
Question from Nilangan : "I have a recurring problem with hardware. Can't diagnose the issue"
MERGED QUESTION
Thanks mod, can you change this thread to Discussion thread?
To others, I went 3 days without facing issues after unplugging and replugging cables except for the "graphics card driver stopped working and recovered error" which happened just few minutes after using chrome after doing the unplugging replugging that day. Today I am facing issues again. A little different again. I was working on chrome flawlessly for hours before starting to experience glitches. First my screen just froze I had to force restart the PC, it was working and suddenly froze, showed artifacts http://imgur.com/a/Zn7y3 went blank and came back again showing drivers recovered similar to what I have mentioned before. I have seen this error 3 times in total all spanning in last 15days. http://imgur.com/a/G71GR
I worked for 15-20 more minutes before getting a BSOD which showed the exact same error like the ones I have mentioned before. http://imgur.com/a/89uYZ but this time after rebooting I was able to use the computer but chrome is glitching specially when using facebook. It showed me Nvidia Share stopped working. The screen goes black. I closed chrome. Started again. same issue for facebook. I closed chrome went away for a few minutes runned HD tune test and now I have copied few files to and from my mobile using USB and now using tomshardware, imgur, fb via chrome. No issues
Here are stats from open hardware monitor http://www.beetxt.com/8m4/
Here is the HDtune screenshot you asked for.
http://imgur.com/a/YOj7x
CAN I POTENTIALLY BE DEALING WITH TWO ISSUES? ONE WITH HDD and GPU. Ps- GPU is new. Using it with Antec VP550P
I have this one https://www.newegg.com/Product/Product.aspx?Item=N82E16814487263&cm_re=1060-_-14-487-263-_-Product# . Btw after posting this it ran well for few minutes before chrome again went blank and unresponsive, I have a CPU RAM meter win 7 gadget whose background went pink for some reason and the PC froze. I turned it off and replaced my HDD sata cable with the cable which was used with DVD drive and plugged the HDD to the DVD sata port. I restarted the PC. Its working fine but chrome froze once while using three tabs (one fb) I reopened it. Working now. Will try to play GTA 5 on another copy of windows and see what happens. Btw on HD tune I can still see current pending sector 200 200 0 7 warning and Interface CRC Error Count 200 200 0 4 attention
EDIT- I tried performing a quick test on WD Diagnostics and got this error http://imgur.com/a/WKVlf
