Question I have a rx 580 special edition and i need help| Tengo una rx 580 especial edition y necesito ayuda
Mar 18, 2025
I have an 8+6-pin special edition RX 580 and a non-modular XPG Pylon 550W 80plus Bronze power supply with two 8+6-pin connectors. I've seen videos that show it's risky to connect the power supply and the RX 580 this way, since they say they must have a modular PSU with one 8-pin and one 6-pin connector, but I don't know if it's risky. Can someone clarify this question for me? Thanks.
Tengo una rx 580 edición especial de 8+6 pines y tengo una fuente de poder no modular Xpg Pylon 550w 80plus bronze con 2 8+6 pines. He visto videos que es riesgoso conectar la fuente de poder y la rx 580 así, ya que dicen que deben tener una psu modular con una de 8 pines y otra de 6 pines, pero no se si sea riesgoso. Alguien me puede aclarar esa duda. gracias
It has nothing to do with (non)modular PSU. Best way is to use separate cables for each input but that card is not power hungry like some stronger ones. 8+6 should be enough.
