Question I have a system with i5 3550 p8z77 m pro..I want to add GPU 1660ti or 2060 rtx
A M
May 8, 2019
9
I have a i5 3550 (integrated GPU)with z77 m pro 8gb (4*2)Corsair Vengeance DDR3 ram,psu cooler master 665w ,system.i want to add GPU 1060ti or 1650 or 1660ti or 2060.currently no plan to upgrade before 2021or 2022.so can I add GPU or not?
iMatty
Notable
Mar 14, 2019
1,092
132
890
11
Well the power supply you have is a really poor quality power supply.
Before buying a new gpu you should consider buying a new good power supply instead.
A M
May 8, 2019
9
Ok I will try..to buy a new PSU..
But currently PSU working fine in system..
iMatty
Notable
Mar 14, 2019
1,092
132
890
11
Well yeah it is working fine in the system, but it is not a good quality one, plus to begin with you didn't even have a graphic card and now you are adding one, that power supply wont be enough to supply enough power which can fry your components.
And before buying another power supply ask, some of them are cheap knockoff that you shouldn't buy for a rig.
A M
May 8, 2019
9
Ok ..which PSU I should buy?
A M
May 8, 2019
9
I5 3550.. Mobo asus p8z77 m pro..ram Corsair vengeance 8gb(4*2).. 1tb wd blue,500gb Samsung hd,80gb hd old wd black,24 inch monitor,LG DVD rw+,Hp ps2 mouse,mid tower case
A M
May 8, 2019
9
M12ii 520 bronze not available.. just Seasonic S12II 620 BRONZE, SS-620GB available, other Brand's like Corsair CX CP-9020103-NA Semi-Modular 80 Plus Bronze 650W,Corsair CP-9020122-NA 650W,Thermaltake PS-TRS-0500NPCWEU-2 TR2 S 500W,Antec HCG750 High Current Gamer Bronze Series 750W,Artis AR-VIP 1000W 1000 Watt SMPS,CORSAIR RMX RM1000X 1000W ATX12V / EPS12V 80 Plus Gold Certified, Circle Gaming APFC Modular 750 Watt 80 Plus..
Latest posts
