I have a Toshiba laptop does not want to work on the battery and the battery light does not blink white and light main shippin
Do the following steps and see if it helps.
Switch of everything and unplug the charger from the laptop.
Take the battery out.
Plug the charger to the laptop and the power supply and switch your laptop on.
If it switches on, your laptop is OK, the battery is the problem part.
If it doesn't switch on, take it to a service center.
If it switches on, again turn it off, unplug, put the battery back and charge it for around 30 minutes and then switch it on. If it works normally and shows that the battery is charging, it is good news. Charge it fully and then run it only on battery to see how long it runs.
If it doesn't charge, but laptop works normally otherwise, replace the battery.
