I have a toshiba satellite pro but when i turn it on it says "No bootable device, insert boot disk and press any key. Can some
Are you certain it is set to boot the correct drive? Or that the drive wasn't erased?
If you can, I would try entering the BIOS and see if it is set to actually boot the drive where your OS is installed.
Now if for some reason the OS is no longer on the computer, or the hard drive failed and needs replacing, then you will need to re-add the OS to the or replace the drive and then add the OS back.
