the connection is called jrgb and it won’t fit it as the XWD 3pin cable doesn’t fitSounds like that should be the RGB connector. Your case should say what type of RGB the fans are, some are proprietary and you need to connect them to a hub the case comes with. You then need to look at your motherboard manual and see what RBG headers is has (5v or 12 v) to match that to the case fan connectors.
