Basically I recently upgraded to an FX-9590 from and old Athlon II, so my friend decided to do the same. However the FX-9590 would not work on his 970a-G43 motherboard, while mine does... So I looked it up and discover that the motherboard doesn't support the FX-9590 because it's over 200w. So, you can see why I'm confused. I'm running it, but he can't. And also I would like to know if I should worry about any adverse effects when it comes to running the FX-9590 since it doesn't support it...
