I have this motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813132697
This is my GPU: https://www.newegg.com/Product/Product.aspx?Item=9SIAD2C5AX5031
Here is my Wireless Network PCI Adapter: https://www.amazon.com/gp/product/B00TQEX7AQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Anyway, everthing works correctly but my Network adapter wont fit in the first PCI slot because A screw is sticking out from the top and the I/O is blocking it from going in by like a millimeter. I put it in the next one which is right under my GPU. They are almost touching each other with a millimeter of clearance. I think one of my GPU fans is hitting against the wifi card because when I am in a game I hear a little scrape sound and gets progressively louder. The first time I heard it, I got so scared I immediately killed power and then found that this was the cause. My GPU is on the first PCIE slot. Would I be able to move my GPU down to my second PCIE slot so the Wifi card would be above the GPU and therefore not scrape against the fan?
